2006 RX330 When I insert the ignition key it buzzes
Old Dec 21, 2011 | 06:40 PM
Montimar1's Avatar
Montimar1
Default 2006 RX330 When I insert the ignition key it buzzes
On my 2006 RX330, on occasion when I insert the ignition key I get a buzz for a fraction of a second. Car starts OK and no tell tale signs of a problem. I have changed the battery in the key and still the same. Any body have a clue. Never happened before.
Old Dec 22, 2011 | 06:04 AM
draco's Avatar
draco
Insertion of the key is normally followed by the steering wheel moving back to it's last position. Perhaps your steering wheel depending on how you have set it is a fraction out from where the car would normally retract the steering wheel to. Hence when you put your key in, it moves back to that spot just outside the "retraction" area.
Old Dec 22, 2011 | 11:44 AM
jamodeo's Avatar
jamodeo
Do you put the key in the ignition as you are closing the door with your other hand? If the door is open and you put the key in it will chime until you either remove the key or close the door, so maybe you are just sometimes just closing the door as you insert the key?
just a thought.
-Joe
MyGirl470
GX - 1st Gen (2003-2009)
Jan 3, 2019 10:43 AM
kdb0925
IS - 1st Gen (2001-2005)
Nov 25, 2007 01:44 PM
LX450SD
CL of Southern California
Jan 14, 2006 11:21 AM
daryll40
May 2, 2005 01:44 AM
