Please help with Check Engine, VSC, Trac Off warning light
Old Dec 18, 2010 | 09:03 PM
LEP XEP's Avatar
LEP XEP
Default Please help with Check Engine, VSC, Trac Off warning light
Hi Everybody,
I did the search but couldn't find anything related to this code P0031.
My wife RX is due for 60k service. Last week, I replaced the engine air filter and the cabin air filter (Thanks to Clublexus). After driving for a week, the Check Engine, VSC, and Trac Off warning light is come on. I went to Autozone and ran the code. It's P0031 (AF Sensor heater control circuit low, AF sensor heater relay fault, failed AF ratio sensor). I got the definition from the print out. Does anybody know what cause this or what need to be changed? I tried to push the Trac control button under the driver knee but didn't change anything. Should I connect the battery to clear the light?
I'm about to flush the coolant, drain and fill the transmission, brake fluid, and power steering fluid next week.
My wife RX is still under CPO warranty. Should I take it in even though I'm not doing the 60k service with them?
Any help is greatly appreciate.
Old Dec 18, 2010 | 10:33 PM
RX330inFL's Avatar
RX330inFL
Does not matter where you have your service done. Vehicle is still covered under the CPO warranty. Take it by the shop or give them a call on Monday. They should even give you a loaner car while the warranty work is being performed.
Would hold off on your to-do list until this is complete. Just in case anything they need to do takes one of those items off the list for you.
Old Dec 19, 2010 | 07:41 AM
cjs18's Avatar
cjs18
The broad definition of the code you mention is Mass Air Flow circuit malfunction. Since you mention that you replaced the engine air filter, might it be worthwhile to make a quick check to see that your MAF sensor is properly connected? If found unplugged the dealer might consider the visit a non-warranty expense. Some folks could be inclined to disconnect MAF to gain additional movement to get the filter element out / in.
Old Dec 22, 2010 | 08:14 PM
LEP XEP's Avatar
LEP XEP
I checked all connection around the air filter box and did not see any loose connection. I will call them right after Christmas.
Thanks everybody. Merry Christmas and Happy New Year!!!!
FredM
RX - 1st Gen (1999-2003)
66
Apr 6, 2021 09:31 AM
wzwz8221
Dec 16, 2012 05:10 PM
jcjr
May 19, 2010 03:00 PM
diverchris
Jul 18, 2009 07:53 PM
yoshi
Nov 6, 2007 10:45 AM
