Can't remove Oil Maintenance Required Light
Old Jun 1, 2018 | 09:32 AM
mandyfig's Avatar
mandyfig
What kind of car do you have?
Originally Posted by RUSmiling
Hi All, dash was replaced couple of years ago under recall by dealer. Afterwards I was unable to control passenger windows rolling down, setting seat position, resetting maintenance required, and dimming nav screen to night view. Trip ODO also was not accessible. I have since (thanks to YouTube) been able to reset windows and seat position control, which gave me hope about the ODO problem. I have followed the steps to reset maintenance required, holding button down with ignition off, then turning ignition on. I've held it down from around 5 seconds to 30 seconds in multiple attempts with no luck. Anyone have a solution or thought as to what is going on? Many thanks!
Old Jun 2, 2018 | 07:20 AM
RUSmiling's Avatar
RUSmiling
Default '04 rx 330
'04 rx 330
Old Oct 3, 2018 | 12:18 AM
GaryC17's Avatar
GaryC17
Hi All, sorry to dig up an old thread. Just did an oil change even before the maintenance light came on. Attempted the procedures as above but the ODO does not changed to the dashes. Does the maintenance light need to be turned on already before this works?
Old Oct 3, 2018 | 09:14 PM
ToledoRX's Avatar
ToledoRX
No, the maintenaince light does not need to be on already for this feature to be reset. If you changed your oil at 5000 miles and want to reset it, you can do it by pressing down on the ODO button and then turning the key to the ACC.setting.
You need to hold the ODO button for more than 5 sec for the it to be completely reset. There should be a countdown timer on the odometer if you did it correctly.
Old Jul 6, 2020 | 09:42 AM
funnydays's Avatar
funnydays
Default I had the same trouble
Thanks for this thread. I’m from foreign county so first I’m sorry for my poor English.
I was struggling as you reseting the maintenance required light until I found this thread. But several tries, I finally reset the light.
I have 2008Lexus RX350
The point is pressing ODO/TRIP button and turn ignition to ON almost at the same time.
I pressed ODO/TRIP button first then turn the ignition so no 6 dash appeared on the odometer.
Once you know the right procedure, it is so quick!
hope this will help other Lexus owners.
Old Sep 22, 2024 | 06:49 AM
oldCarsAreABlessing's Avatar
oldCarsAreABlessing
1st Gear
Default Do not start car
I kept scrubbing this up because when I switch the key to on, I also started the car! That does not work : you need to leave it on and wait
ephisig764
May 12, 2011 02:37 PM
Rykster
Apr 15, 2011 08:46 PM
DocRock143
Dec 7, 2006 01:19 PM
Lextranny
Jan 18, 2005 01:23 PM
gsdsclark
Aug 11, 2004 06:56 PM
