How to make your car quieter
Can anyone help me find some rubber rolls to buy? My Lowe's did not seem to have any, or they did I nor an associate could find it. I would rather not order it online. Thanks!!!
I found some old rolls of sound proofing materials for car audio in my gagrage - and decide to take this project on. Well it actually makes a difference. Can't say it's going to make you jump out of your seat with joy-but you can tell the difference.
I went a different way in applying the material. I removed the tool box and the from box were the cargo cover is stored. So I had the whole rear floor paln opened .The material I used was in the coventional roll type-were one side is glued for adhesion. I covered all the area's on the floor that had no factory material applied. even in the corners were the rear bumbers start. and then on the cross bar I did not cover the holes with material since the factory music amp was there and some other computer was back there. what i did there I applied the materail on to the cross bar itself-leaving the opening open. I did however aplied some of the materail inside that inner space were the amp was. sorry for no pics-but the camera batteries were dead. my reasoning on applying the materail to floors is that the sound will travel through the body of the car-vibrations. so the heavy materail would muffle it a bit.
Recommend product
I have a sports car that was made with almost no soundproofing and I decided to add soundproofing to reduce the noise. I did quite a bit of research on various products, some of which have been mentioned above. I chose to use B-Quiet Ultimate and I'm quite pleased with the results. The product was reasonably priced and was relatively easy to use. The noise reduction is quite noticeable. You can use products that are intended for other purposes but the cost of using an ideal product is pretty small relative general car expenses. I've included a link below. There are product comparisons and how-to pages on the website. And no, I am not affiliated with the company at all, I just want to share my recommendation for a good product. After seeing this post I'm going to use my leftover product on my 04 RX. http://www.b-quiet.com/ultimate.html
If the link doesn't work a quick search will find the site.
The fill is the same stuff that's inside pillows. You can purchase it in big bags at any yardage/sewing store, or tear into old pillows. It's also in sleeping bags.
http://www.lowes.com/pl_Exercise+Flo...__s?Ntt=rubber
More than enough, don't know if it's what you're looking for though.
I did this today to my rear back. I ordered some "fat mat" from eBay and covered the back. I have 2 and a half sheets left and I was going to pull the carpet on the rear passenger floor to cover, but it seemed like a lot of work. I might tackle the front driver and passenger doors tomorrow.
my suggestion for housing subs under there. two words. Shallow mounts.
Im putting 2 8s under mine right now. I was planning on using dynamat underneath. Dynamat is heavier, but I highly doubt its going to be enough to reduce gas mileage or braking lol. It wouldnt be more than having a passenger.
In my opinion, front/cabin noise is dampened well with noise reduction and absorption but trunk was the area that was bothering me. Thanks to this post, I now can see the culprit.
From my limited experience with sound deadening, it appears that this area needs both mass for vibration/noise reduction AND filler for absorption. While I do see factory deadening in there (gray material), it could definitely use more for vibration reduction. My plan is to do both by putting down dynamat-type deadener to increase mass (thus reducing vibration) and filling with acoustic foam such as this to absorb:
http://www.soundproofcow.com/Convolu...oam-Panel.html
I'll be tackling this next week, I'll update once done.
