Gear Shifter Console bulb blown?
I cannot find this searching anywhere however the Gear Shifter is no longer illuminated at night. The ETC Snow Button is lit normally however the selector P, R, D, 4, 3, 2 is now not illuminated. I am assuming a bulb, but how in the holy heck does that thing come apart? Anyone know a part #?
Thanks, Bobby |
Bump anyone help?
All I know is you can twist the shift knob counterclockwise to remove it and the wood trim for the gear shift will pop off if if you pull straight up on it.
I found the part number for the bulb for my car there are 2 , the one I need is 3590648030 my lex parts.com has it. My only thing is how the hell does that shifter console come part? I know the knob that is easy but getting below the indicator panel to the bulb..
Bump on this.. I cannot figure out how to get the shifter indicator out to replace it with the bulb. I have the bulb... anyone know??
try this but you have to figure out about the bulb
https://www.clublexus.com/forums/rx-...-04-07-rx.html |
These bulbs must be made in China or something! cause they sure dont last very long.
how do you take apart shifter to get to bulb?????
Originally Posted by ojeda70
(Post 8139816)
You might find the answer your are seeking here: https://www.clublexus.com/forums/rx-...n-shifter.html |
