Front Brake Vibration
Old Sep 7, 2007 | 11:30 AM
jednav's Avatar
jednav
It's amazing how people will cheap-out on brakes/rotors thus endangering the lives of others.
Old Sep 7, 2007 | 11:36 AM
Dinomon's Avatar
Dinomon
Due to the issue (plus my VIN # is included in this TSIB), I thought Lexus would have replace the rotors and pads as per the attached TSIB. Any ways, I can get them replace those? Thanks!!
File Type: pdf
Old Sep 7, 2007 | 11:50 AM
TunedRX300's Avatar
TunedRX300
Originally Posted by johncdoyle
The issue with rotors is that they have to act as a heat sink and the more mass they have, the more effectively they can do this. When you cut the rotors, you remove material and diminish the rotor's ability to absorb as much heat. For most of us who don't do severe braking, turning the rotors (as long as they remain within tolerance) never presents a problem. For those whose rotors warped in the first place because of overheating, turning them will be a temporary solution. Because I don't like removing material from the rotors, I generally do not automatically turn them as part of a routine pad replacement. I only turn them if the surface looks bad or if I'm getting pedal pulsating symptoms. I have been replacing the rotors every other pad replacement and I think that's a very conservative approach to maintaining enough mass in the rotors so that they won't warp easily. The Germans appear to have gotten away from turning rotors altogether (Mercedes and BMW at least) and routinely replace rotors with pads. I think that is overkill and have gotten excellent results with pad replacement only. While some will tell you that it will take longer for the pads to break in, I have not found it to be a problem and the pads seem to be fully seated after a couple hundred miles.
I completely agree, the argument of new pads bed-in quicker with a smooth surface is not valid because 1) microscopic pore still exist on freshly cut or new rotors, what is smooth to the naked eye is not really smooth at the frictional surface 2) both pad and rotor surfaces are constantly re-shaped by every brake applications. 3) cutting rotor is the inferior solution to brake warping, it does not increase heat disspation surface or capability of heat absorption.
Old Sep 10, 2007 | 09:01 AM
dhamaka127's Avatar
dhamaka127
Could any one suggest any aftermarket rotors they have used on their RX? non OEMs?
Thanks...
Old Sep 10, 2007 | 09:03 AM
andreys's Avatar
andreys
Thanks...
Very good aftermarket rotors, which are even better than OEMs, are Brembos. You can get either cross-drilled (more expensive) or regular (less expensive). Both will do a great job on RX.
-- Andrey
Old Sep 10, 2007 | 09:20 AM
jfelbab's Avatar
jfelbab
Thanks...
I've used their rotors on my MR2. Nice product with lifetime warranty.
http://stores.brakeplanet.com/Items/es22634?
Old Sep 10, 2007 | 09:28 AM
dhamaka127's Avatar
dhamaka127
-- Andrey
Any suggestion on brakes while you are at it?
Are you using Brembos currently?
Old Sep 10, 2007 | 09:32 AM
dhamaka127's Avatar
dhamaka127
Thanks....200 bucks for 4 rotors and brakes is not bad...
Old Sep 10, 2007 | 09:33 AM
andreys's Avatar
andreys
yeap.
I purchased the regular version of Brembos (non cross-drilled) since RX330 is not a racing vehicle by any means. Since the purchase, my wife put almost 40k on rotors without any issues of warping or vibration.
Old Sep 10, 2007 | 09:36 AM
dhamaka127's Avatar
dhamaka127
yeap.
I purchased the regular version of Brembos (non cross-drilled) since RX330 is not a racing vehicle by any means and put almost 40k on them without any issues of warping or vibration.
Thanks for the help...where did you purchase them? any deals on them?
Old Sep 10, 2007 | 09:48 AM
andreys's Avatar
andreys
I got mine from http://www.tirerack.com/
You might want to check with them as they often have these rotors out of stock due to their low price and rotors popularity.
Old Sep 10, 2007 | 10:05 AM
Kostyan's Avatar
Kostyan
Andrey,
what pads are you running with those Brembo rotors: OEM or aftermarket?
to all-
Do brake parts from a Toyota Highlander exactly match RX330's for the same model yr? How much are you paying for Lexus OEM rotors and pads?
Old Sep 10, 2007 | 10:39 AM
andreys's Avatar
andreys
rotors - brembos (from tirerack)
pads - performance friction (from AutoZone, lifetime warranty)
I believe HL rotors / pads should be identically the same. At least that's what my system shows.
Old Sep 10, 2007 | 07:13 PM
cdnewton's Avatar
cdnewton
I am so frustrated with the OEM rotors on my wife's 2004 RX330 AWD, next time the rotors warp on our 2004 RX330 (to date, they have warped at 26K, 52K, 62K and 74K and the TSB has been applied -- so it will happen again); I will order the performance rotors from brakeplanet or the Brembos.
After the problems we have had, the lifetime warranty from brakeplanet is intriguing, because Lexus hasn't cared much once we were beyond the warranty.
Old Sep 10, 2007 | 11:10 PM
TunedRX300's Avatar
TunedRX300
Originally Posted by cdnewton
I am so frustrated with the OEM rotors on my wife's 2004 RX330 AWD, next time the rotors warp on our 2004 RX330 (to date, they have warped at 26K, 52K, 62K and 74K and the TSB has been applied -- so it will happen again).
What kind of "remedy" was offered to you for each case and who implemented them at how much $?
