LockPick
Old Apr 21, 2007 | 06:11 AM
Capirato's Avatar
Capirato
Default LockPick
Does anybody know if the RX 350 and the ES 350 NAVs are the same ??
http://www.coastaletech.com/DELUXE_LOCKPICK.htm
http://www.coastaletech.com/ULTIMATE%20IPOD.htm
~ Cap
Old Apr 21, 2007 | 04:25 PM
Ken's_RX's Avatar
Ken's_RX
I don't know, but they probably are.
I have the LP3 basic - it does eliminate the "I Agree" and does allow navigation input while driving ( not perfect, but does work) ..
-Ken
Old Apr 21, 2007 | 04:43 PM
sama's Avatar
sama
-Ken
Hi, are you using LP3 basic 07 RX350 and do you have 6.1 Nav . In one earlier post you mentioned -- it sort of works...
Old Apr 21, 2007 | 07:56 PM
tfischer's Avatar
tfischer
25 Year Member
The first post caught my interest, but upon further reflection, I think that for $250.00 I'll just keep on touching the "I Agree" button for a while.
Jeeezz. For 250 it ought to serve tea at 4.
Old Apr 21, 2007 | 08:15 PM
Capirato's Avatar
Capirato
Default LockPick
-Ken
Ken.....
Coastal Tech does not list the ES 350. But it does list the RX 350.
I think I'll order the kit for the RX and try it on my ES.. If it doesn't work, I'll give it to my grandson who just bought an '08 RX350.
~ Cap
Old Apr 22, 2007 | 12:40 AM
AM1's Avatar
AM1
CL Folding 100,000
i think the vaistech unit also has a function to bypass the i agree screen
Old Apr 22, 2007 | 06:13 AM
Ken's_RX's Avatar
Ken's_RX
The Lockpick 3 Basic is only $99. not $250. It gets rid of the "I Agree" screen - most of the time. If you go into reverse before allowing the "I Agree" screen to come on and have the LP3 push the button for you - when you return to drive, you will still have to press the button. I would rate this a 95% solution.
The nav override also is not perfect but does work. When you go to the DEST screen while driving the buttons remain greyed out. To activate the override you press the red pin in the upper left of the screen. It then electronically switches off the speed sense to the nav and the buttons all light up allowing input. After a few seconds they will again go grey for a few seconds then light up again allowing input. So you can use it sort of. Not perfect, but workable. I would rate this also a 95% solution. Oh, one other thing - while the LP3 in navi mode is active, the nav system will not track you. If you're close to a turn that you needed to make, you may pass it before you're done making a new destination and going back to the map screen. When you go back to map, it takes a few seconds for it to re-find you and create the routes.
And, I am using this on an '07 RX350 with 6.1 map s/w.
Install takes less than 5 minutes.
It did take 3 units from Coastal to get me one that worked, but they did keep sending me units untill it did.
-Ken
sharmila19
Apr 4, 2017 04:51 AM
Seeker4
RX - 4th Gen (2016-2022)
Feb 9, 2017 09:20 AM
jcmarathon
RX - 3rd Gen (2010-2015)
Apr 28, 2011 11:49 PM
mefromfl
27
Mar 17, 2011 09:14 PM
Capirato
Apr 18, 2007 12:30 PM
