Aftermarket wheels
Old Mar 29, 2007 | 09:46 AM
MTF's Avatar
MTF
Default Aftermarket wheels
I was just wondering if anyone has put aftermarket rims on a 2008 RX350? I am looking to do so but have been told that I can't because of the tire pressure monitoring system. Can anyone help me out?
Thanks
Old Mar 29, 2007 | 11:15 AM
CK6Speed's Avatar
CK6Speed
While I can't speak for actual RX350 owners, I can't see why the TPM system will cause much of a problem. Well, actually it does make selecting rims more troublesome as the aftermarket rim barrel has be be able to accept the TPM valve stem. That said, many LS/GS/IS owners that use the newer valve stem TPM system have put on aftermarket rims. You do have to either remove the TPM valve stem from your original rims and mount them on the new rims, or buy another set of TPM valve stems to mount on the new rims and have them initialized or registered at the dealer. By that I mean the dealer needs to program the new TPM valve stems to your car so the TPM system recognizes it.
Old Mar 27, 2009 | 08:51 PM
phatmic's Avatar
phatmic
how can it be disabled ?
i have a set of wheels but do notwant to invest another 200$ in sensors.
does anyone know how to disable the TPM on a 2007 RX350
thanks
Old Mar 27, 2009 | 08:58 PM
benzo555's Avatar
benzo555
thanks
The TPMS cannot be disabled, but you can build a pvc pipe bomb for it.
Old Mar 27, 2009 | 09:27 PM
phatmic's Avatar
phatmic
euuuh can you explain ?
Old Mar 27, 2009 | 10:02 PM
phatmic's Avatar
phatmic
please explain as i read on other threads that it is possible to disable the TPMS ECU but it wasn't a thread for an RX
thanks
Tg22ar
May 10, 2017 10:03 PM
Ay-nako
Dec 20, 2008 04:14 PM
d6500k
Mar 15, 2007 06:05 PM
Donger
GX - 1st Gen (2003-2009)
Apr 12, 2005 10:42 PM
KevGS4
Wheels, Tires & Brakes Forum
Sep 27, 2002 05:29 PM
