HID Conversion KIT
Old Nov 14, 2006 | 10:03 AM
vdt04452's Avatar
vdt04452
Default HID Conversion KIT
hello everyone!
I'm planning to install the HID conversion kit to my new RX. I'm wondering if anyone had any problem with aftermarket kit :
'The kits will plug in and everything but its their
responsibility to do some research and make sure their
vehicles are compatible with an aftermarket HID kit.
Some vehicles' computers freak out when they dont see
that a normal bulb is attached and then it wont send a
signal to the ballast to fire up the HID. This
happened on a Dodge truck and a special harness had to
be ordered to trick the ecu. So just tell them to
check some forums and find out if others had installed
aftermarket HID kits with no problems or additional
harnesses to trick the ecu.
Thanks,
Old Nov 14, 2006 | 12:40 PM
Booyah's Avatar
Booyah
Wow..I didnt even know the RX could be had without HIDS
Old Nov 14, 2006 | 03:42 PM
CK6Speed's Avatar
CK6Speed
Yes, the RX could be had without HIDs. I've installed HID lights in other cars and had no problems. One thing to look out for is the polarity of the harness plug. Different cars use different polarity so if the kit doesn't work at first, you may have to just swap the polarity (Swap the plugs wires on the kit) and it should work.
Old Nov 14, 2006 | 04:58 PM
sharpener's Avatar
sharpener
IMHO, it would be better to get the RX tat *** equipped with projector xenon
Old Nov 15, 2006 | 12:45 PM
Todd's Avatar
Todd
Default Also may need
ballasts and/or other secondary electronics
hoonami
36
Apr 1, 2010 08:28 PM
gsobol
GX - 1st Gen (2003-2009)
200
Oct 30, 2009 05:55 AM
grouch
Jan 24, 2008 12:21 PM
