Rear Winshield Spray
Old Dec 11, 2005 | 12:24 PM
MatadorIS's Avatar
MatadorIS
Default Rear Winshield Spray
I've had my 04 RX330 for more than 2.5 years and it has never done a good job of spraying the rear windshield with the washer fluid. Rather than spraying, it just comes dribbes out in 1 or 2 spots. Is this a problem with my car, or is everyone else's the same?
Old Dec 11, 2005 | 09:22 PM
Booyah's Avatar
Booyah
It should not dribble out! Should have a nice stream--2 streams actually.
Put a needle up in the spray hole as it may be clogged
Old Dec 11, 2005 | 10:34 PM
cantsleepnk's Avatar
cantsleepnk
Mine does the same thing too .I thought that was normal
Old Dec 12, 2005 | 04:44 AM
MatadorIS's Avatar
MatadorIS
I guess you could call it 2 streams, but it's not like the typical front ones that have a wide spray nozzle.
Old Dec 12, 2005 | 05:50 AM
Lil4X's Avatar
Lil4X
Out of Warranty
It's probably designed that way, as most other wagons, vans, etc. are. A fine spray could be whipped away from the window at speed. I've gotta go stick a pin in those nozzles myself - this weekend I was down to one stream.
81corolla
RX - 1st Gen (1999-2003)
15
Dec 14, 2006 01:47 PM
jeffyjeff
Dec 22, 2005 05:07 PM
dms666
Nov 23, 2004 08:15 AM
slowtan
Nov 12, 2003 02:30 PM
bob2200
Oct 19, 2003 11:55 PM
