Removing trunk silver trim?
Old Sep 16, 2005 | 12:37 AM
thwang99's Avatar
thwang99
Default Removing trunk silver trim?
Anyone know how to remove this silver trim?
http://www.lexus.com/assets/models/g..._gal_img_1.jpg
The chrome piece below the rear "L" and above the license plate. Thanks!
- Tony
Old Sep 22, 2005 | 06:01 AM
krpster's Avatar
krpster
I will check later today and let you know
Old Sep 22, 2005 | 06:48 AM
krpster's Avatar
krpster
Tony
First you must remove the mid section cover on the inside of the hatch. This is the hard plastic section. It is just clipped in so you will need to pry it out. Try grabbing from the edge at one side and pulling out it should "pop". Once started you should be able to continue to the other side "popping" out the remaining clips.
The trim piece is held on by 5 nuts (see below) and one clip. You will need to remove the nuts from the inside of the hatch. The trim should then just pull out with the remaining clip.
Overall a pretty simple procedure. Why do you want to remove it?
Old Feb 6, 2006 | 06:03 AM
us000011's Avatar
us000011
Default RX300 Lift Trim
Does my strip above the plate come off the same way ythis one does? Looks like a similar mounting.
The RX300 strip is not chrome, though- It's matched to body color.
XF40FSPORT
RX - 3rd Gen (2010-2015)
12
Sep 21, 2025 07:25 AM
nsxtacy
Oct 21, 2015 11:56 PM
dotwprod
Dec 4, 2014 11:46 AM
us000011
RX - 1st Gen (1999-2003)
Feb 10, 2006 11:35 AM
