Trunk only opens 2 feet
Old Jun 5, 2025 | 05:31 PM
Efy20's Avatar
Efy20
2nd gear
Default Trunk only opens 2 feet
Hi my trunk only opens 2 feet even manually when the power is off replaced the struts that wasn’t the issue any insights will be greatly appreciated
Old Jun 8, 2025 | 01:59 PM
Felix's Avatar
Felix
If the hatch won't open all the way either manually or powered, I'd be looking to disconnect the linkage on the drivers side of the C-pillar. Seems like the liinkage is hung up. I'd somehow prop the hatch open the 2' & drop the rear seat back down & carefully remove the Driverside C pillar cover & disconnect the lmotorized linkage to the hatch, That'll allow you to open the hatch all the way manually. Then you could figure out if the motor itself is the issue.
Old Jun 9, 2025 | 04:06 PM
Efy20's Avatar
Efy20
2nd gear
thank you I unscrewed it and it works I’m going to leave it off since the power doesn’t work either way I really appreciate your help
Old Jun 9, 2025 | 06:34 PM
Felix's Avatar
Felix
If the hatch motor only works a little bit, I'd just replace the motor, you'll possibly find the motor w/ the linkage on ebay. Just be cool w/ the headliner.
Old Jun 10, 2025 | 11:19 AM
Margate330's Avatar
Margate330
My wife uses the power tailgate but I never do.
Just as easy for me to grab it and lift up.
Old Jun 17, 2025 | 05:12 AM
ElChili's Avatar
ElChili
10th Gear
What was the fix?
Old Jun 28, 2025 | 07:30 PM
Felix's Avatar
Felix
Originally Posted by ElChili
What was the fix?
He ended up removing the linkage from the hatch & the hatch opens by hand. Sounds like it needs the hatch motor. I'd check the relay/fuse first thou.
Z250c
IS C
15
Mar 20, 2022 05:56 PM
Playdrv4me
Oct 11, 2019 09:09 AM
SerasLibre
Sep 17, 2009 03:14 PM
mayonnaise
Nov 16, 2008 07:27 PM
