Has anyone here replaced the fuel injector seals on their RXs with one of the various kits out there? Mine are original and I want to re-seal them as they slightly weep from the gasket where they sit in the lower intake manifold
Yep got the kit from Amazon or eBay that about $10 also cleaned the injectors using the shreader valve stem and brake cleaner method shown on YT... happy to find the link if you'd want. Replace the plastic coil connectors while there too (just depin your wires and repin with new plastic
Instead of hot gluing I just used good electrical tape on the Shraeder valve. I have a couple wires with insolated alligator clips on both ends I made up for various projects like he shows to get power to the injectors they are very handy for lots of projects. A second set of hands would be helpful but I was able to do fine alone. Works like a charm! Shraeder valves were bought from Walmart
Replacing injector seals... I think I only did the larger base seals the others looked fine if I remember right, a dab of superlube silicone grease on all of them makes fitting them easier plus should give them longer life. My injector rail popped out and leaked a bit during an aggressive romp through very rough potholes on a dirt road so it was a good time to do all of them as they were very dried, cracked, and shrunk down.
