Lexus repair shop
Not from FL but any good Honda/Toyota shop should be fine despite our ego's there's nothing special about them a specialist isn't needed.
Depending on the year with 200K miles things to look for:
When was timing belt, water pump, serpentine belt, thermostat last changed?
Condition of radiator? (not expensive nor hard to replace)
All rubber bits - lower front control arms, ball linls, sway bar bushings, sway bar links. If not alrady done they will be in need desperately
Tune-up - (spark plugs, all air filers, oil and filter, transmission oil, transfer case and rear diff fluids, brake fluid)
Hood and tailgate struts (very cheap andd easy to replace)
