Tranny failure? Advice
Old Feb 15, 2023 | 08:23 PM
treywin's Avatar
treywin
2nd gear
Default Tranny failure? Advice
While on highway truck started slipping and not picking up speed. Pulled over had no drive gears or reverse. Truck now is whining on cold start and does shift into reverse and drive, once at temp whining noise stops and truck stops going into gear. Pulled codes from truck pertaining to shift solenoid b and d , fluid is full but had not being flushed since my ownership. Not sure if it’s worth getting transmission looked at has 192k miles
Old Feb 15, 2023 | 08:29 PM
It's worth spending around $100 to find out if the transmission can be revived. Some shops will even drop the pan and give you the news for free.
Old Feb 16, 2023 | 08:10 AM
salimshah's Avatar
salimshah
25 Year Member
Don't put the conclusion before listing your choices and consequences.
You might end up with a choice that was not your first reaction.
Example 5K to fixup something with a sweet value after repair of 4K. Does not seem very logical but you might want to invest 1K in something that is a known entity,
Salim
jpv7774
Oct 10, 2023 05:06 PM
Sherl
Dec 5, 2022 09:38 PM
ariasuriah
Jul 6, 2009 05:25 PM
trufanatic
Oct 31, 2008 08:33 AM
Dbl400Trbl
May 25, 2005 01:10 AM
