Transmission Fluid Change?
Old Dec 11, 2013 | 07:39 AM
shivanm27's Avatar
shivanm27
soo the transmission oil caters for the 4wd too ? or is the 4wd oil is placed in a separate hole ??
Old Dec 11, 2013 | 08:28 AM
Lexmex's Avatar
Lexmex
Two separate holes,
gear oil/4WD oil,
https://www.clublexus.com/forums/rx-...-case-diy.html
transmission,
https://www.clublexus.com/forums/rx-...er-change.html
Old Dec 11, 2013 | 10:53 AM
salimshah's Avatar
salimshah
25 Year Member
Originally Posted by additude
I am changing mine out in my driveway this weekend or next. I did it on my LS 400 last week and it was pretty smooth.
I got the ATF from irontoad.com for $4.95 a qt.
In case you want to here are the steps.
Get one of those 2qt plasic measuring pitchers from the store, or use your wifes, like I did, only don't tell her. Get an oil change pan. I use the kind that is inclosed with drip holes in the top from Walmart. Get a long neck plastic funnel, like from AutoZone. Walmart probably has that also.
Drain the transmission pan, keeping track of how much tranny juice you take out. My LS dropped 3 qts. from the pan.
Now put the plug back in the pan and put how may qts you just drained out of new ATF back in.
Disconnect the tranny cooling lines at the bottom of the radiator. Put the measuring cup on the oil change pan and point both lines down to the pitcher until you know which line is the exit side.
Have someone start the car, drain 2 qts and stop the car.
Put 2 qts in.
Start the car and drain 2 qts.
Put 2 qts in.
You can stop now if the last exit of tranny juice looked nice and red.
If not do it again. Drain 2, replace 2.
That should do it.
Cost was about $60 including oil pan, funnel and pitcher.
It can be done in an hour. Cleanup and all.
The above process gets most of the old fluid out, but it does not remove the sediments. I would suggest draining through the drain hole too. If you want to clean the magnets, you will have to drop the pan.
Salim
Old Dec 11, 2013 | 07:05 PM
shivanm27's Avatar
shivanm27
Default he heh eh
Originally Posted by Lexmex
thanks buddy once i put the oil in the oil hole ill be good
hsmac
34
Jul 28, 2021 09:12 PM
RX350LB
Jun 21, 2019 09:08 AM
ccc70
42
May 18, 2008 03:44 PM
Vagus
Dec 14, 2004 02:51 AM
jimbo22s
Jul 9, 2004 07:36 PM
