heater
Old 10-19-18, 04:41 AM
Jodeen1
Jodeen1's Avatar
Default heater
So I have a lexus rx 300 my heat blows cold I try switching ***** to defrost to floor to just front vents and they don't adjust settings and blows cold no matter what the setting is please help
Old 10-19-18, 07:33 AM
salimshah
salimshah's Avatar
Welcome to Club Lexus.
There are two adjustments ... Mode and Mix. The mode controlled by the ****/switch and usually under 'Auto' in controlled by an ecu. Ecu keeps changing the mode [where the majority of the air is used out vents/screen/floor etc.
The Mix is controlled by the temp setting [hot/cold] and is again driven by ecu.
The final mechanical action is done by 'servo' and these servos go bd with time.
You seem to be having problems with both.
Do a search and it will give you plenty of threads.
Two friendly reminders ...
1) Please add some description to the thread title as that helps people who can respond and other people who search.
2) Read through the sticky threads. Most of the information any one seeks is in there.
Salim
Old 10-19-18, 01:18 PM
ukrkoz
ukrkoz's Avatar
Thank you, Salim, for explanation.
OP, that is great guide - if you actually even get heat to the heater core. About the only way to find out is to get to the heater core hoses and touch them by hand. If both are hot - read what Salim says. If one is hot one is cold - you either have clogged core, with no coolant flow through, or coolant is blocked from getting to it. This sometimes happens when there is air plug in the system. Maybe, I am not sure, never tried, you can reach from the floor up under the dash and feel the core. Is it even hot?
Also, how is coolant level? Radiator and expansion canister?
musicman67
10-04-18 03:17 PM
oldwino
ES - 6th Gen (2013-2018)
03-12-18 06:55 PM
ivnnln
11-12-12 02:23 PM
strack18
03-05-09 08:36 AM
jeffyr163
Maintenance
11-20-04 08:55 PM
Quick Reply: heater
