RX 300 steering issues?
This will be my first post, and i'm hopeful someone can help me. After looking around for a couple of months, i bought a 2001 RX300 with 125K miles. It had about 20 miles on a rebuilt transmission, new brakes, and about 3 month old tires. It seemed to be a pretty good car, has some normal wear but nothing big. Today, while I was out driving with my wife in a winding canyon, the car suddenly lurched to one side and some alarm on the dash started going off. I was frankly too busy trying to keep the car under control to look at the instruments to see if some light was flashing. It felt like it had a flat tire. I could hear something rubbing. Then it stopped, and as i was trying to figure out what was that (?) it did it again only a few hundred yards later, stopping almost as soon as it started.
I got the car home, it did not happen again. But I am noticing that the steering wheel is centered sometimes, and sometimes it is about 20 degrees left of center when going straight. I have no idea what is going on with this, can anyone point me in the right direction?
Super Moderator
w1437 (09-16-18)
Took the car to a local shop, messed around a little then finally put in on a 4 post life with the weight on the suspension, cranking the wheels back and forth you could see the rack on one side moving 1/2-3/4 inch. Tightened it up, checked the alignment, all is well now. Thanks Lexmex, if you're ever in Denver lunch is on me-
oxonian
RX - 1st Gen (1999-2003)
05-04-16 10:53 AM
