Performance Difference between Transmission U14E and U140F
Old Oct 14, 2017 | 10:59 AM
abendeck's Avatar
abendeck
Default Performance Difference between Transmission U14E and U140F
Lexus RX300 2001 TRANSMISSION interchangeable U140E AND U140F
Old Oct 14, 2017 | 11:12 AM
abendeck's Avatar
abendeck
Exclamation Continuation of Requested information
I bought a used low mileage Transmission. They sent me a U140E model. Previous one was U140 F. should I return it? Can I get a new U140F CONVERTER and replace into the U140E transmission. Is there a performance difference between the two transmissions or just the converter?
Old Oct 14, 2017 | 01:14 PM
kitabel's Avatar
kitabel
F is AWD, E is FWD, won't work.
Old Oct 23, 2017 | 03:24 AM
Australian's Avatar
Australian
There is an upgrade you can do that is fitting a cooler in, Mine never had one from factory but does now. As far as performance goes you can make the car move but if you choose to drive it at its peak performance it be short lived.
Old May 15, 2019 | 04:08 AM
murphysf's Avatar
murphysf
I heard the difference between the U14E and U14F is that one is for 2WD and the other is for 4WD.
Not sure if this is true.
Anyone know?
Old May 15, 2019 | 04:18 AM
murphysf's Avatar
murphysf
I just found this:
"The U140E/F ("F" for F/awd) used in the RX300 from the "get-go" has a completely different transaxle control setup, solenoids, etc, plus the transaxle internal structure is quite different mechanically.
I guess he U140E was for the RX300s that were just FWD?
Old May 16, 2019 | 11:53 AM
maxSteel's Avatar
maxSteel
Anyone know?
U140E is for FWD. U140F is for AWD
See:First doc has table of application by vehicle
murphysf
May 17, 2019 04:23 AM
dlexus1
Aug 4, 2013 08:39 PM
boo1678
Mar 19, 2013 11:15 PM
tawm
Dec 21, 2007 09:08 AM
tmuti13
Jul 24, 2007 07:48 PM
