Need help with; Ignition Cylinder Removal,
Old 01-28-17, 02:29 PM
BlueJ
BlueJ's Avatar
Default Need help with; Ignition Cylinder Removal,
I had trouble with my 99 RX300, couldn't turn the key at all, read online that giving it a few light taps should un-seize it a bit
It did and now I think I rigged the anti theft because the starter keeps cranking but won't turn over Took off the surrounding pieces but I was stumped on how to move further
144K on it
Old 01-28-17, 02:46 PM
JAB
JAB's Avatar
When you say 'won't turn over' you mean despite the fact that the starter has engaged and is rotating the motor, it won't run, correct?
Old 01-28-17, 02:47 PM
BlueJ
BlueJ's Avatar
Yes, it keeps cranking and won't get running
Old 01-28-17, 03:04 PM
JAB
JAB's Avatar
I had to have the ignition cylinder and lock replaced on my 1999 RX300; it is not something you can do yourself. Yes, you have obviously disturbed the immobilizer sensor. Send me a message with your email address and I will send you a picture. Not able to upload it to Club Lexus for some reason.
Old 01-28-17, 05:06 PM
BlueJ
BlueJ's Avatar
just got it running and moving, it was definitely the immobilizer system, I'll pm my email address in a second, thanks again!
Old 01-30-17, 12:39 PM
aznlapin
aznlapin's Avatar
If the black & clear trim piece (hanging piece on bottom right of your photo) isn't on the ignition switch, the car will never start. It'll crank and crank, but you need that trim piece sitting on the ignition switch to fire up.
jclrx300
01-19-11 03:10 PM
immax01
05-03-10 05:20 AM
the3rd
Performance & Maintenance
03-25-10 10:32 AM
SillsyB
10-09-08 09:34 PM
Ice350
14
12-07-05 11:55 PM
Quick Reply: Need help with; Ignition Cylinder Removal,
