Window switch relay CR2-12V NAIS
#61
I replaced the relays in both the driver side and passenger side of my Lexus RX300 with ACJ2112 relays after not being able to find a source for CR2-12V relays. I found the ACJ2112's on Ebay for $2 each. Thanks to everyone for previous posts on this thread. They were very helpful.
Attachment 409938Attachment 409939Attachment 409940
Regards . . .
#62
After trying unsuccessfully to find the CR2-12V, I ordered ACJ2112 relays from ebay for $2 each. 3 pins need to be linked together, and then the relay fits quite nicely upside down on the circuit board where the old relay was previously located, as long as you solder the wires in such a manner that they go downward from the relay to the board. I purchased a box of six differently colored solid-core 18 AWG wire and a new variable temp soldering iron on Ebay for this project, and it made it much easier. If you haven't already solved your problem, you may want to refer to my photos in my post at the end of this thread.
#63
Found and ordered this one from ebay for $40, worked like a charm!
NAIS CR2-12V ACR231
http://www.ebay.com/itm/182617396955?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
NAIS CR2-12V ACR231
#65
I am interested to find out if the post is for real or simply a spam as same thing got added to 4 different threads by a new member. I have blocked the post in other threads.
Salim
#66
I originally suspected he is the ebay vendor. If he is, I doubted he would post the photo. If not, hopefully he or someone else will post with some info to confirm the validity of the claim.
#67
Its the NAIS!
Hi Lexmus, yes its a NAIS relay... I didn't get a picture of it before installing, but it fit fine... the pins lined up with the holes... it wasn't as pretty as the original with the nice case, but it worked just like it supposed to, up and down!
#68
Hi Salimshah, sorry for for the multiple posts, I searched hi and lo for this relay through these posts and others as I've been driving around with a plastic on my window for weeks and I've tried every thread on these links only to find they were sold out or discontinued, so I finally found it on ebay and thought I'd share the good news!!
#69
Salim
#70
#71
https://www.clublexus.com/forums/rx-...ml#post9735800
#72
No. CJ pinning is different from the original CR.
http://www.sears.com/panasonic-elect...FdaMfgodhkQKaw
Desperate
#73
I am not aware of any direct replacements. There are functionally similar H bridge relays available from Panasonic, but the pinning is different.
You have to wire them in place.
#74
Like alex2324, I ordered one of these from eBay and it works fine. I am glad my windows work again.
http://www.ebay.com/itm/NAIS-CR2-12V...72.m2749.l2649
