Engine troubles, error codes, looking for input
Old Aug 3, 2015 | 09:35 AM
snorander's Avatar
snorander
Default Engine troubles, error codes, looking for input
I've got a 2000 RX300 with 177,xxx miles on it. Last night the check engine light started blinking, the car started to run rough, esp at idle when in gear. Light is now solid. Error codes are as follows:
-Random/multiple cylinder misfire detected
-Cylinder 1 misfire
-Cylinder 2 misfire
-Knock sensor 2 circuit band 2
I have narrowed the problem down to cylinder 2. when I unplug the coil there is no change in the engine, unlike what happens when I unplug the cylinders. I tried a new coil hoping that would fix it. No luck still have the same problem.
I took it to a shop near my office today and they diagnosed it with low compression, possibly a valve.
When I get home from work tonight I'll verify the compression. Anyone have any thoughts on what I should check or look for?
Old Aug 3, 2015 | 03:54 PM
snorander's Avatar
snorander
Compression on cylinder #2 = 90, compression in others 180
Oh well it was a nice car while it lasted
Attached Thumbnails Engine troubles, error codes, looking for input-img_1712.jpg   Engine troubles, error codes, looking for input-img_1711.jpg
Old Aug 3, 2015 | 05:15 PM
maxSteel's Avatar
maxSteel
Couldn't it just be a head gasket?
If it's a valve, I see prices for remanufactured heads ranging from $250-$450.
Old Aug 5, 2015 | 06:02 AM
snorander's Avatar
snorander
Does not appear to be a head gasket, still trying to decide what to do.
Old Aug 5, 2015 | 01:39 PM
snorander's Avatar
snorander
Leak down test & boroscope tomorrow to see if it is the valve or the piston.....
Old Aug 6, 2015 | 11:20 AM
snorander's Avatar
snorander
Leak down test confirms bad exhaust valve on cylinder #2. Boroscope shows a very sketchy piston in cylinder 2 as well. Looks like I will be ordering a long block since I put a new transmission & differential in this car about 3 years ago
ChanceM40
Mar 8, 2022 04:22 AM
LMSeal
Aug 31, 2018 07:45 AM
chenxingha
Apr 21, 2018 11:04 AM
Aqueon
14
Jun 24, 2015 07:22 AM
ProfessorP
18
Apr 8, 2009 06:29 AM
