RX300 ABS issues
Old Jan 1, 2015 | 02:59 PM
rickl289's Avatar
rickl289
Default RX300 ABS issues
I really hate to post another ABS thread but I'm can't seem to figure out the problem.
I have been driving the 2000 AWD RX300 without ABS for a while (pulled connector by ABS per lexmex's post) but recently replaced the alternator and battery so I want to fix the ABS too. The problem seemed to appear after a front brake change (new pad and rotors).
I followed many different thread on debugging the ABS like this one but still can't find the problem.
I measured the ABS sensors with a DVM and got around 1.7k ohms on each.
I pulled the front ABS sensors and verified the reluctor rings are not broken or loose. I pulled the left rear axle and verified the reluctor ring is good. I replaced the left rear ABS sensor after I broke it trying to check the reluctor ring.
After the alternator and battery update, I was getting codes 11, 14, 22, 24, 34 and 41. See BillJoeBob's post.
11 = open circuit in ABS control solenoid
14 = short circuit in ABS control motor
22 = open or short circuit in 3-position solenoid circuit left front
24 = open or short circuit in 3-position solenoid left rear
34 = left rear wheel speed sensor
41 = low battery positive voltage or abnormally high battery positive voltage.
I cleared the codes following page 7 and ran the speed sensor check (see page 8).
Now I get 71,72,73,74,75,76,77, and 78. Seems like something is causing all codes to appear. I'm not getting any of the above codes (11,14,22, ...) any more.
Any thoughts?
mroxas
27
Oct 12, 2018 12:17 PM
Smokie
Feb 18, 2018 08:35 PM
price999
25
Dec 5, 2013 09:12 AM
Gomer1
13
Oct 28, 2010 08:42 AM
faithless
Jun 20, 2008 01:36 AM
