2000 RX300 ABS Problem
Old Nov 29, 2014 | 12:31 PM
Mindo80's Avatar
Mindo80
Default 2000 RX300 ABS Problem
Hi Guys! Would anybody know what might be wrong when ABS turns on when hitting brakes at low speed?
Old Nov 29, 2014 | 06:17 PM
carguy07's Avatar
carguy07
Broken reluctor ring or dirty/broken speed sensor. Probably clean the speed sensors first and try to inspect the teeth on the rings.
https://www.clublexus.com/forums/rx-...when-rain.html
https://www.clublexus.com/forums/rx-...tone-ring.html
Old Nov 29, 2014 | 06:40 PM
Wht95scort's Avatar
Wht95scort
Rear speed sensors are pulling away from the knuckle due to rust build up. The change in gap from the ring causes false readings and makes the abs kick on.
Old Nov 30, 2014 | 12:40 PM
Mindo80's Avatar
Mindo80
Thank You Guys!!! I'll make sure to check both of those and will write which of those caused the problem.
HtownBlue
Aug 25, 2024 06:48 PM
Darzan23
Apr 15, 2017 07:00 PM
bchehab
Oct 1, 2012 09:14 AM
splacek007
Aug 13, 2010 07:13 PM
Androu
May 6, 2009 06:24 AM
