Can an exhaust leak trigger a code 1133?
I know you are chasing a CEL, but please do not underestimate the problems related to exhaust leak.
Carbon monoxide is a silent killer. This weekend on NPR some one talked about a near death experience due to exhaust leak.
I would place higher priority on fixing the leak over fixing CEL.
Salim
Salim
I don't know that I have a leak, nor do I suspect that I have one; I just don't want to spend the time and money changing out the rear bank A/F sensor if I'm not confident that a worn-out sensor is the cause of the code.
My bad, I misunderstood your post.
None of the codes mean a problem with the sensor. We generally swap out the sensor and the most of the time the problem goes away.
My recommendation is to use OEM sensor only.
Salim
Salim
dbullen
Aug 9, 2010 02:15 PM
