intermittent fan blower
I have a 99 lexus with an intermittent fan blower. Sometimes it comes on sometimes it doesn't. For example it worked when I went to work this morning and did not work this afternoon. Sometimes when it's not working it just kicks on after driving it some. The fan control works showing me the desired fan level I want so I am guessing its not the switch. and since it kicks on and off at will I am guessing its not a fuse. Any help would be great.
Originally Posted by gulfjoe
(Post 7223813)
(Post 7223830)
Its an RX300
(Post 7223813)
Patience Grasshopper :)
There is a relay module tucked under the blower motor near the air mix servo. Mine went out at about 175K miles. Pretty easy to replace but a pricy part. I bought mine from Sewel Lexus. You may like to confirm that it is the failed part. Salim |
Have not heard back?
Before you get the relay, check the blower motor and connections leading to it. Salim |
Originally Posted by salimshah
(Post 7224226)
(Post 7230517)
Where abouts would that be located? Under passenger side dash?
If you want to look at some pics, search on "air mix servo" or "mode servo". Be aware that some folks have them mixed up but they are close to the relay. By your description the ecu is sending the right voltage out (you can see the bars on the display), the relay takes these voltages and iterprets it to right amount of juice to the blower. So the suspects are the relay, connector(s), wire(s) and the blower. Relay has known to fail and imho the used parts are too risky to buy (the module is not sealed), specially if you intend to keep the vehicle. Salim |
(Post 7231086)
Yes!
(Post 7233081)
Will I have to take out as much stuff as you did to replace that relay? I didn't quite see where the relay was located can you show which pics had the relay
Salim |
(Post 7234062)
Can you point me to which thread and which post you have/are looking at. Based on that I can give you the location.
Salim |
(Post 7234156)
https://www.clublexus.com/forums/gs-second-generation/399744-diy-on-changing-servo-motors.html
Third picture shows a far shot of Toyota (green colored decal) part, That is the relay. It also appears in the 2nd and 5th picture. It is held in place by one screw on the top and has two prongs in the bottom... so it would not come straight off...flop it over. Blower motor is not visible in the pictures but it is situated right above the relay. Once again verify that the blower is OK before you buy the relay. Salim |
