door handle lost screw
Wondering if anyone has encountered this problem. Apparently there are two screws that hold the door handle in (drivers side in my instance). One of them came out. I looked at the post for removing the door panels, but not sure if this will get me to where the screw has been lost. Ideas? Help.
thanks in advance.
abc
thanks in advance.
abc
That should definitely get you to where you need to go. I seriously doubt that the screw is small enough to get out any drain hole on the bottom of the door. Take a look 1st to see if any of the drin holes look large enough for that to happen.
ahmed24
May 8, 2010 03:38 AM
