'02 Door Lock Actuator
Old Jun 19, 2011 | 10:14 PM
lserlohn's Avatar
lserlohn
Thanks for Lexmex's excellent Tutorial in https://www.clublexus.com/forums/rx-...moval-diy.html
I am wondering do I need to remove all of the door panel to replace the actuator? Or just parts of it is enough.
Old Jun 19, 2011 | 11:54 PM
code58's Avatar
code58
The entire door panel must be removed for either a "piggyback" installation or and OEM actuator replacement.
Old Jun 22, 2011 | 05:33 PM
richonline's Avatar
richonline
The door panel should be off in less than 15mins, of course with the help of the diys here. I removed 3 of them last Sunday for 10mins each.
Old Jun 25, 2011 | 02:03 AM
trips1's Avatar
trips1
I am planning to use piggyback method to fix my driver side door lock.
Please can someone help me with the following questions:
- Should the window glass be rolled up or down when doing this.
- I have the old ebay universal door lock actuator that was earlier used by everyone in this forum. Do i need to grind the actuator rod to make it use the limited space or that is not needed?
- I am hoping if i mess up in connecting the wires and if it does not work then i can reverse wire connections without damaging anything.
I am just trying to collect all the information and tools before taking up this task :-)
Thanks in advance.
Trips.
Old Jun 26, 2011 | 12:39 AM
code58's Avatar
code58
Trips- my suggestion would be to do a "search" because there have so many good (thorough) posts on the subject that it is almost pointless to repeat, since I don't believe they can be IMPROVED upon. Also do a search on Lexus Owners Club. If you need more clarification, PM me as I've done a # of them and would actually make a few small changes from what I've done in the past, at this point.
emckenzie
Apr 29, 2021 03:49 PM
greg3852
Nov 30, 2019 08:04 AM
Bri-Guy
May 17, 2008 07:45 PM
