rx300 p0302 fault code
It's not to hard to get at at that coil. Just reach behind there with a 10mm wrench (preferably a small one) or something else you can take a bolt off and remove it and pull the coil out.
I think with the cast code you are referring to that must be P0171 (ignore that one).
I'd buy if possible (and this makes sense any time you have a misfire and have replaced the coils) to run some fuel injector cleaner through it. You can readily get something like Chevron's Techron or Lucas Fuel Treatment at most auto stores though if you get your hands on Redline Fuel System Cleaner (Pep Boys) or Amsoil's Fuel Injector Cleaner (some Carquest stores carry it), those are all good cleaners.
Also, when you went out this morning was the check engine light flashing or did it just light up and stay lit?
Also did any of the codes have a P/D or PD by them?
No, you don't have to remove anything for that coil.
Can any one educate me on Pending codes.
Every thing starts as pending and if it persists over time it moves into Active fault. If the fault persist, does the pending (if it is a queue) keeps getting set.
Putting it in different words,
If you get an active fault and NO pending fault (same code), the error occurred in the past and now it has fixed it self and over time if no new errors fault is detected it will clear itself.
Corollary: If you get an active AND pending faulr (same code), the error is still being detected.
The above can be applied to multiple codes.
Salim
Salim
Is the vehicle also rougher (no pep or real acceleration)?
Lexmax, thanks for giving me the confidence to pull coil #3 out w/o taking anything apart! It was tough but if you didn't assure me I wouldn't haven't even tried. So, I swapped #3 w/ #2, as of now it's not coming up on the computer. I'm going to get another coil for the #2 and see what happens. The car is still rough hopefully because of that bad coil that I'm replacing today.
I'll keep you posted, thanks again.
Lexmax, it worked, replaced coil #3 and the ovc and it seems like it's running the way it should be. I want to thank you, wish I would have read more on the forums before panicking and taking it to Lexus where they really stuck it to me.
I appreciate your knowledge and expertise.
Take care
Take care
Having familiar problems, changed out all coils and plugs, also added fule injector cleaner but still rough idle and steady CEL returned. Only thing I haven't replaced is the OVC cause i'm not sure what that is. I need a clue, please HELP!!
Oacjuly, just be patient and don't go rushing to the dealer like I did. Lex, will walk you thru and save you a lot of money. I changed out the OVC also, easy to do. I'm far from being a mechanic and this was a joke. I can't believe they (dealer) charges people to swap out these parts.
Good luck
Good luck
OK, so i am younger and I just bought my lexus rx300 .. I love it!! However, right when I got it I noticed it had a low idling problem. Every couple of weeks when I would start it it would idle real low and sometimes shut off if i didn't keep my foot on the gas peddle. Well I looked on a few sites and it said to clean the iavc valve, well I planned on doing that myself (i do many things myself), but all of a sudden my lexus started sputtering (this morning) and its not idling low, its just sputtering real bad and sometimes wont go past a certain speed. This made me worried so I immediately took it to autozone where they gave me this code P0302!! cylinder 2 misfire. So this site has helped me plenty in the past, so i figured before I would do something irrational and spend 1000 dollars I would come here and see what experts have to say.. Any help PLEASE!
Why I say lucky, #2 is in the front (near radiator on passenger side). You can swap coil pack and or spark plug to narrow what is wrong. You can even lay down the plug with coil pack and see if the spark is there.
Salim
i just changed the spark plug, and its starting to sound worse ... maybe the coil pack
? now my whole vehicle is jumping when i change gears .. and its idling low again and will shut off if i let go of the gas ..
.. I dont know what to do other than buy a 75 dollar coil pack and hope for the best .. :/ any other suggestions!
.. I dont know what to do other than buy a 75 dollar coil pack and hope for the best .. :/ any other suggestions!Do not attempt to diagnose/trouble shoot in desperation. You may get lucky, but most likely you will be replacing things that are good to begin with.
Salim
Instead of making a new thread, I decided to post here. I replaced knock sensors 1 & 2, got my car back from the dealership with a new code P0302. It was obvious the dealership messed it up, since my car was running fine before, would you guys take it back to the dealership or try replacing ignition coil yourself? Thanks
