Something went bump :(
Old Dec 7, 2007 | 09:50 AM
  #91
edbro's Avatar
edbro
Originally Posted by Lexmex
Apparently there was a lot of gunk in the torque converter (oxidized fluid) and so obviously I am happy to clear it out.
Are there any additives that might help with this as preventative mx?
Old Dec 7, 2007 | 10:05 AM
  #92
Lexmex's Avatar
Lexmex
None that I am aware of. I know some torque converters have drain plugs (but even that requires something similar to what we just did in separating the tranny from the engine block).
You can see some of the gunk in this photo just near the bottom of the pump. That was after we had removed the torque converter. That narrow hold on the shaft is where the fluid enters the torque converter.
Attached Thumbnails Something went bump :(-img_3572.jpg
Old Dec 7, 2007 | 07:17 PM
  #93
Lexmex's Avatar
Lexmex
We are a little over half way done, maybe about 60% or so. Transmission has been mounted. We need to put in axles, lower suspension and connect a few things. We might have finished today, but power went out around 5:30 p.m. in the neighborhood, meaning no light and no power for the air pistol we need to tighten down some bolts, so we will go at it again tomorrow morning.
However, I of course took some photos.
Transmission has been painted silver. I later found out that the reason for this is not aesthetic. Rather, due to flooding that we had in Mexico City, Chinito would see a much higher number of transmissions coming in for service. He used the analogy of sticking a hot pan in cold water. The end result could be that internal components could weaken due to the sudden temperature change. I still however keep my transmission fluid dipstick open to let out heat.
Attached Thumbnails Something went bump :(-img_3660.jpg
Old Dec 7, 2007 | 07:18 PM
  #94
Lexmex's Avatar
Lexmex
Another shot of the tranny.
Attached Thumbnails Something went bump :(-img_3661.jpg
Old Dec 7, 2007 | 07:20 PM
  #95
Lexmex's Avatar
Lexmex
There is the new pump I ordered and there are also new seals on the front differential unit to the left.
Attached Thumbnails Something went bump :(-img_3662.jpg
Old Dec 7, 2007 | 07:21 PM
  #96
Lexmex's Avatar
Lexmex
Old flywheel and new flywheel sitting on the torque converter which has been painted black (it was opened fixed up (modified) and rewelded).
Attached Thumbnails Something went bump :(-img_3663.jpg
Old Dec 7, 2007 | 07:23 PM
  #97
Lexmex's Avatar
Lexmex
My uncle's hand putting some sealant on the side of the transfer case (this will hook into the front differential).
Attached Thumbnails Something went bump :(-img_3664.jpg
Old Dec 7, 2007 | 07:25 PM
  #98
Lexmex's Avatar
Lexmex
Torque converter. From what I was told, they opened the one off of mine and the one off the other RAV4 tranny, and I have no idea which one they used but apparently one of them at least had an issue (might have been mine given the sounds I was hearing before).
Attached Thumbnails Something went bump :(-img_3665.jpg
Old Dec 7, 2007 | 07:26 PM
  #99
Lexmex's Avatar
Lexmex
Notice the weld on the side of the torque converter.
Attached Thumbnails Something went bump :(-img_3666.jpg
Old Dec 7, 2007 | 07:29 PM
  #100
Lexmex's Avatar
Lexmex
I had the book out. My uncle and I actually had to look at it once to see which side the flywheel faces the torque converter (as we weren't sure if it was installed right to begin with but eventually after the manual proved useless we took a look at my old photos and figured it out. That was the only time my uncle had to look at it, but I referred to it a few times when hooking the electrical connections and also tomorrow when I hook up that park/neutral safety switch or whatever they call it on the front of the transmission.
Attached Thumbnails Something went bump :(-img_3667.jpg
Old Dec 7, 2007 | 07:32 PM
  #101
Lexmex's Avatar
Lexmex
Here we are taking a look at the flywheel and the position of the end of the starter.
Attached Thumbnails Something went bump :(-img_3668.jpg
Old Dec 7, 2007 | 07:33 PM
  #102
Lexmex's Avatar
Lexmex
My uncle Antonio after installation of the new flywheel.
Attached Thumbnails Something went bump :(-img_3675.jpg
Old Dec 7, 2007 | 07:34 PM
  #103
Lexmex's Avatar
Lexmex
End of starter and torque converter.
Attached Thumbnails Something went bump :(-img_3676.jpg
Old Dec 7, 2007 | 07:35 PM
  #104
Lexmex's Avatar
Lexmex
Wider shot of previous photo.
Attached Thumbnails Something went bump :(-img_3677.jpg
Old Dec 7, 2007 | 07:37 PM
  #105
Lexmex's Avatar
Lexmex
Front differential. We tested the new seals by dumping some ATF in the rear fill hole, and all was well.
Attached Thumbnails Something went bump :(-img_3679.jpg
