Leaking drain plug
Old Aug 31, 2007 | 10:40 PM
deus85's Avatar
deus85
Default Leaking drain plug
I've been having a problem with my rear differential drain plug. I followed the instructions on here to replace the fluid. The car was left in the garage for a week and a half undriven, and upon returning I discovered a slow leak from the plug. It was rusting down there, so that may have caused the seal between the transmission and the plug to be loose. I also replaced the plugs with new ones from the dealer.
I would appreciate any advice on what to do now. It is a hassle to have to open the fill plug to fill up the fluid, so I'd rather find a way to fix the leak.
Thanks.
Old Aug 31, 2007 | 11:01 PM
salimshah's Avatar
salimshah
25 Year Member
New washer and correct torque.
Salim
Old Sep 1, 2007 | 10:11 AM
deus85's Avatar
deus85
I torqued it to 36ft-lbs. How much should it be? 40ft-lbs?
I purchased the new plugs from the dealer. It didn't come with any washers. Should there be one on there?
If so, what size/etc.
Should I obtain that from the dealer, too?
Thanks a lot!
Old Sep 1, 2007 | 08:20 PM
salimshah's Avatar
salimshah
25 Year Member
The drain plug is re-usable.
The gasket must be replaced and the proper torque is 36 lb-ft. Although not required, but the dealer has the right part number.
note: both the filler and drain gaskets should be replaced.
Salim
Old Sep 1, 2007 | 11:07 PM
deus85's Avatar
deus85
Thanks a lot.
I had forgotten all about the washings because I threw the old plugs away when I purchased the new ones. I just assumed everything necessary came along with it!
I called the dealer and asked, and purchased the washings today. Pathetic of me; now I have to drain the Royal Purple fluid to put the washings in.
Old Sep 1, 2007 | 11:13 PM
salimshah's Avatar
salimshah
25 Year Member
Out of curiosity, why did you discard the plugs? Did they get stripped?
Tip: Some times the washers actually prevent the plug from travelling too far.
Salim
Old Sep 5, 2007 | 10:08 PM
deus85's Avatar
deus85
Salim
Yes, I stripped the plugs. Would have saved 20 something bucks if I hadn't (not including the washers at $2 a piece)!
I went to Toyota dealership with the old plugs, and was told that they don't have those, and that Lexus is trying to "move away" from Toyota. I guess they want to separate the two lines instead of allowing the parts to be interchangeable so they could charge more for Lexus parts.
doggystyl
Hybrid Technology
60
Dec 15, 2025 05:17 PM
dcdyd
Apr 11, 2013 08:58 PM
joeyv821
IS - 1st Gen (2001-2005)
Sep 9, 2008 06:07 PM
cal_alum98
Maintenance
19
Apr 14, 2005 10:20 AM
Curt
Maintenance
Feb 17, 2005 08:37 AM
