Vehicle Speed Sensor (VSS)
I'm installing navigtion system into my RX. Alpine nve-N851A navigation system has to be connected to the VSS (vehicle speed sesor). :eek:
Does anybody know where can I find VSS in the car and what is the color for the wire?
Thank you
Thank you
Jmezo,
I couldn't find white/purple wire for the VSS. The only one I could see is white and red wire going to/from computer (the upper block of it). Is it the same wire?
Please tell me (if I'm wrong) where exaclty can I find white/purple wire - there is a computer and there are multiple wire hubs to the right of the computer.
I don't think my mute (on nav system) is working - there no negative (ground) is coming out whenever system is talking.
I know - I have connected this wire correctly because if I put ground on it - the radio will mute.
Thank you for your help.
You can e-mail me directly to kslavik@hotmail
I know - I have connected this wire correctly because if I put ground on it - the radio will mute. Thank you for your help.
The red/white is not it! I don't recommend you doing this part of the install!
Its been a long time since I worked on it but I know its on the passenger side. Could be the kick plate, under the dash or behind the glove box.
The nav will not talk until you are on a route. Looks like you have the right mute wire on the radio though.
Your nav unit may need another ground wire...
Prost
Nov 30, 2005 10:03 PM
