Premptive radiator replacement?
Looking for opinions...
I have a 1999 RX 300 with 63,000 miles. It's in mint condition, and I have no plans to ever sell it.
Given that it has plastic radiator parts, should I consider preemptively replacing the radiator? We use the car for 2 - 4 hour trips on occasion (lots of cargo space), and I would like to avoid mechanical damage or getting stranded.
- If it fails, is the design such that coolant could mix with the transmission fluid?
- Is the typical failure mode small cracks/small leaks, or is it something more catastrophic?
The upper radiator support makes it difficult to see the radiator to look for discoloration, etc. I already had the upper and lower hoses replaced. Heater hoses, thermostat and radiator cap are already on the to-do list.
Thanks!
Thanks!
If your concern is plastic top developing a leak, iyou will only loose coolant.
Typically you develop pin hole leaks which produce white powder spray pattern.
I would not preemptively change radiator. If there is an indication only then.
Salim
Salim
Thanks!
Thanks!
Thanks!
Thanks!
https://koyorad.com/product?s_make=l...99&s_freeword=
Lexicon1
Mar 7, 2017 09:02 AM
gs2impress
GS - 1st Gen (1993-1997)
Oct 22, 2010 02:53 PM
