1999 Radio Antenna Not Coming Out
So I'm trying to replace the radio antenna, and I know it should be a 10 minute job, but when I turn on the radio with the antenna nut undone, the antenna is not exiting the tube after turning on the radio the way it does so nicely in all of the YouTube videos I've seen
What am I missing? And thank you in advance for any advice.
What is the reason to change the mast?
If it is broken or bent, then at least one section is deformed in the inside of the tube. You have to use controlled aggression to get it out.
Salim
Salim
Here's the DIY on replacing the antenna https://www.clublexus.com/forums/rx-...enna-mast.html
Other alternative is to pull the whole motor out. [undo the rear right panelling to access]. This might be more prudent as an errant slip can possibly damage the exterior paint.
There are times when the cable is broken inside the motor assembly and one has to take the motor out. It is mentioned in the DIY that you must match the new antenna and cable to the one you pull out to ensure everything came out.
Salim
Salim
soyhead
Sep 6, 2021 09:51 AM
