Door trim
Old Jan 27, 2026 | 12:54 PM
samasaurus's Avatar
samasaurus
10th Gear
Default Door trim
Is there a thread giving instructions on how to remove RHF door trim?
Old Jan 28, 2026 | 11:42 AM
maxSteel's Avatar
maxSteel
Look for threads on repairs that would require removing the trim, like https://www.clublexus.com/forums/rx-...-write-up.html
Old Jan 28, 2026 | 03:03 PM
salimshah's Avatar
salimshah
25 Year Member
There should be some videos on the net.
The process is pretty intuitive. Look for fasteners arena the edge and around pull points and plastic covering the screw heads. Strat unsnapping the clips from bottom edge. Go by feel and expect clips to break due to age. I prefer broken clips vs damaged door panel. Once the clips are detached, you will need to pull the panel up [vertically] to free it from the door.
Once off undo wires.
Depending on how deep you want to go in, use a heat gun to soften the adhesive on the waterproofing plastic. At the end ensure the plastic membrane is in tact.
If you mess with lock assemble, please verify that it works before putting the panel back up and closing the door.
Salim
17gx460
GX - 2nd Gen (2010-2023)
Oct 1, 2020 11:15 AM
Gotti101
Apr 14, 2012 05:09 PM
tkr1
Dec 20, 2009 02:35 PM
lawrenceO
Mar 3, 2009 08:10 PM
