External Temperature Display Issue
Old Sep 22, 2025 | 03:50 AM
CB700S's Avatar
CB700S
Default External Temperature Display Issue
My 99 has started to have problems with displaying the external temperature on the central stack display. It can be 20+ degrees off, either way. In my experience with other cars, this usually indicates a problem with the wiring to/at the sensor or the sensor itself. Does anyone have a location or picture of the sensor and a chart for testing the sensor? Thanks.
Old Sep 22, 2025 | 04:11 AM
symat's Avatar
symat
3rd Gear
I’m experiencing similar issue. Waiting to get helpful feedback here.
Old Sep 22, 2025 | 08:58 AM
salimshah's Avatar
salimshah
25 Year Member
Partial information here:
Sensor is located in the front gill area and is not protected from minor fender bender and more so in extreme case front collision. You have to get on your knees and peer through the air slots.
As noted the temperature is not an accurate reading at all and it takes about 10 minutes or so to catch up to a change [my estimate] and even then it will be off by 5-10degrees F.
Salim
Old Sep 22, 2025 | 10:43 AM
CB700S's Avatar
CB700S
Salim
Yeah, these aren't the most precise in the world, but this one's just reading well out of the accepted range it so I'd like to replace it or at least check the wiring/casing for damage.
Old Sep 22, 2025 | 11:22 AM
CB700S's Avatar
CB700S
Salim
I didn't see it in the grille area, is it down in the cooling ducts below the bumper?
Old Sep 22, 2025 | 02:49 PM
tammap's Avatar
tammap
Old Sep 23, 2025 | 11:13 AM
CB700S's Avatar
CB700S
Ah, okay, that's where it is. I should be able to find it from there.
vbacky
May 21, 2014 12:18 AM
lonbon
GX - 1st Gen (2003-2009)
Jul 9, 2011 02:45 PM
gs400ny
Dec 19, 2005 08:37 PM
