VVT solenoid
Old Sep 16, 2025 | 10:23 AM
jeremymc's Avatar
jeremymc
5th Gear
Default VVT solenoid
Does anyone know what the Manufacturers date code is on this VVT solenoid?
Old Sep 16, 2025 | 08:54 PM
salimshah's Avatar
salimshah
25 Year Member
We ... or at least I am curious why the interest in manufactured date? Is there a range of bad dates.
The device itself is an electromechanical item with a plunger inside, which opens the oil passage based on voltage. It has a tendency to stick based on quality of oil [and frequency of change of oil] and my limited observation is that its life is more than 120K miles. The screen usually needs servicing and the Orings must be replaced at each service [they tend to harden and give a pretty good fight before allowing the valve to come out. They come as a pair and due to bolt down skirt position are not interchangeable.
I have shared all I know and now its your turn if you choose.
Salim
Old Sep 17, 2025 | 12:14 PM
jeremymc's Avatar
jeremymc
5th Gear
I recently replaced both VVT solenoids. One had markings and the other did not. The vehicle is a 2000 rx300 with 161k.. Definitely an improvement after replacing the solenoids. I'm thinking the old ones were probably the OEM.
Old Sep 17, 2025 | 01:18 PM
salimshah's Avatar
salimshah
25 Year Member
By looking at the condition of the Oring, it has had plenty of time in hot environment.
You can bench test it with 12v battery [full on/ full off]
Salim
az-dave
Performance
134
Dec 7, 2022 08:19 PM
cognus
RX - 3rd Gen (2010-2015)
Jul 30, 2020 03:47 PM
lonnie247
Mar 18, 2014 02:57 PM
trhs75
Jun 9, 2013 06:10 PM
