Radiator Leak - Replacement?
Old Feb 17, 2025 | 01:50 PM
saudiboy's Avatar
saudiboy
Default Radiator Leak - Replacement?
I have the slightest leak at the top left of the radiator. I don’t notice any coolant on the ground or loss of coolant in the reservoir. I only noticed it because I saw a wisp of smoke coming out from under the front of the hood as I was driving today. I’m not usually the driver of the car so I don’t know if this is ongoing.
Us it likely that I would need to replace the radiator. If so, is it a difficult repair?
Old Feb 17, 2025 | 02:55 PM
salimshah's Avatar
salimshah
25 Year Member
No it is easy. You may be able to see a white dried out spray pattern in the engine bay. I may have seen a denso part on Amazon. I would suggest that drain the block and replace the thermostats if those have not been performed.
The only thing I don't know about is the foam packing. The old/existing may not be firm enough to be reused. Maybe some one can give guidance.
Salim
Old Feb 17, 2025 | 08:36 PM
Androman's Avatar
Androman
got a denso from rockauto about a year ago and no problem so far, it was pretty easy and did it myself, definitely want to use the box it comes in and cut out a square to match it and put it on the front of the radiator or you WILL destroy it putting it in. i think i found a guide on here or maybe a YouTube vid dont remember.
Old Feb 18, 2025 | 03:37 PM
saudiboy's Avatar
saudiboy
Thanks. I’ve seen a video for the 2002. The guy disconnected the fan shroud before removing the radiator. I saw another video for a 2000 where the guy said it was a fool’s errand to remove the fan shroud; he took out the radiator and the fan shroud as one unit.
I font know if the conjugations for the 2000 and the 2002 are different. Did you separate the fan shroud before removing the radiator?
Old Feb 18, 2025 | 04:43 PM
Androman's Avatar
Androman
i separated them after, i don't know if they're different either.
xpro
RX - 3rd Gen (2010-2015)
Jul 24, 2024 06:00 AM
jor8888
Apr 1, 2024 03:58 AM
KhanTheMon
Mar 23, 2023 02:44 AM
newnthused
Jan 23, 2023 12:07 PM
VJZ
Feb 5, 2008 04:34 PM
