Driver-Side Window Stuck Down – Guidance needed
Old Feb 9, 2025 | 06:01 PM
ashukla12345's Avatar
ashukla12345
Default Driver-Side Window Stuck Down – Guidance needed
The driver-side door lock and window panel have been acting up for years, but nothing was a major issue—until this morning when my driver-side window refused to roll up. In the past, I’ve managed to get it working by being gentle, trying different window switches, or just patiently praying before attempting again. But this time, the window seems determined to stay down.
I’ve already tried some YouTube tricks, like using tape to grip and pull the glass up, but no luck. If anyone has a suggestion to temporarily get the window up until I can implement a permanent fix, I’d really appreciate it.
For context, it’s a 2000 Lexus RX300 with about 200K miles on it. Thanks in advance for any advice!
Old Feb 9, 2025 | 07:50 PM
maxSteel's Avatar
maxSteel
Search the forum for "nais" for a bunch of threads about the driver door window control and relay. I don't know if you can easily jumper it but maybe just smacking the relay will help
Old Feb 13, 2025 | 01:44 PM
ashukla12345
Checked with my mechanic and he suggested buying a window regulator. Like below one, instead of relay. Any ideas on regulator vs relay for this issue?
Window Regulator For 1999-2003 Lexus RX300 Front, Left Driver Power - Walmart.com
Old Feb 13, 2025 | 02:28 PM
maxSteel's Avatar
maxSteel
I interpreted your original description as "I press the button and nothing happens". That sounds electrical, like the relay, switch, or motor.
But if you press the button and something happens, like the window jerks and stops, or you hear some grinding, then maybe it's mechanical
Old Mar 22, 2025 | 06:32 PM
ashukla12345
Update:
Amazon Amazon
- The window works after replacing "ACROPIX Power Window Switch Window Control Switch Fit for Lexus RX 300 1999-2001 2003 with Removal Tool No.8404048020C0 - Pack of 1"
Old Mar 23, 2025 | 06:23 AM
maxSteel's Avatar
maxSteel
Well, that's easier than soldering in a new relay. Didn't know they made a cheap replacement for the whole thing
Old Mar 25, 2025 | 06:43 PM
Fit1too's Avatar
Fit1too
Wow, thanks guy!
Pablorock
Nov 9, 2022 02:52 PM
Baliztik
Nov 23, 2010 06:46 AM
wusupra
Aug 21, 2008 08:37 AM
