Scissor jack replacement
Old Nov 21, 2024 | 04:50 PM
pieceofbread's Avatar
pieceofbread
Default Scissor jack replacement
I can’t find the weight capacity of the oem jack that came with the 2000 rx300 I wanted to see if anyone knows because I’m looking for a scissor jack with the same weight capacity.
Old Nov 21, 2024 | 05:18 PM
1100 kilograms, there is a sticker on the jack itself. Highly recommend you source an OEM jack, aftermarket is sketchy at best.
Old Nov 21, 2024 | 06:44 PM
salimshah's Avatar
salimshah
25 Year Member
your best and cheapest option would to pick one from salvage yard.
I would not pick any that might have the same rating, but would suggest to get one for the RX or highlander. The Suv are higher up from ground, so you need the proper lift height.
Please be careful in how you use the jack and never coal under the vehicle which is lifted up by the jack.
Salim
Old Nov 21, 2024 | 06:55 PM
09111-0W030 is the correct jack as mentioned salvage yard is your best bet they generally pile them at the entrance. I have 09111-0W030 and another one from an ES300 (year?) they appear to be the same but the ES one is rated for 800 Kg. Not sure if Toyota is using "fuzzy" math or 09111-0W030 has stronger materials.
Old Nov 22, 2024 | 09:29 AM
salimshah's Avatar
salimshah
25 Year Member
I think the difference is in attainable height.
Salim
Georeg
Sep 26, 2022 04:31 AM
maxmethods
May 8, 2007 11:31 AM
