Track Edition Part Numbers
Old Feb 1, 2022 | 08:06 PM
lojackfty's Avatar
lojackfty
Default Half Shafts / Carbon Splitters etc
Originally Posted by Joe Z
Yes I agree if you read carefully these improvements were NOT spec to the Track / Fuji Edition..
The improvements were made to all RC F
Joe Z
Kewl, I'll put the regular shafts on there. With that being said, does anyone know if the carbon fiber front splitter and side diffusers will work on the 19 back. I know the front bumper and side skirts are a little different but are they different where the CF would mount up to?
Old Feb 1, 2022 | 11:40 PM
lojackfty's Avatar
lojackfty
Default Rear Shafts
Originally Posted by LoSt180
All 2020+ RCFs got the hollow half shafts, it's not unique to the track/fuji editions. Actually quite a bit of the items advertised in the track edition also apply to the regular RCF as well. Other than the hood, all of the carbon fiber parts are included in the "Carbon Package" option. If you check all the options on the RCF, it's within $5-6k of the track edition.
I looked at the part numbers for 2020 and though the part number just says RCF and does not designate Track Edition I went back and looked it up for 2019 since I have a 19 and the 2 part numbers are the same. Did they make the transition to the hollow shafts before 20? say starting in 19?
Old Feb 2, 2022 | 01:06 AM
sensai's Avatar
sensai
cool, i see that now abt half shafts and stand corrected. thanks.
Old Feb 2, 2022 | 07:27 AM
LoSt180's Avatar
LoSt180
After I made that post I looked up the parts and pretty much found the same info you did. 20+ with LSD has different part numbers than 2015-2019, but 2015-2021 with TVD have the same part number. Would make sense if they simply changed the part number for all years to the new part, but I'm not in charge of that stuff. The facelift of 2020 has a lot of little tweaks to the platform, the normal online parts databases could be more clear but they also assume you know exactly what you're looking for.
Old Feb 2, 2022 | 06:44 PM
lojackfty's Avatar
lojackfty
Default Still searching for an answer if anyone has this
With that being said, does anyone know if the following two things will work with a 2019 or other years back.
1. Carbon Fiber mounting like the front splitter, and side diffusers.
2. The control module that determines the ride quality. It looks like they only changed the module and nothing else with the suspension that I can find.
Old Feb 2, 2022 | 07:28 PM
05RollaXRS's Avatar
05RollaXRS
Yeah, suspension hardware is the same. The AVS software in SPORT+ mode has a quicker rebound rate in the TE vs non-TE based on what I read.
Old Feb 3, 2022 | 07:38 AM
LoSt180's Avatar
LoSt180
The front will not fit, since those are integrated into the facelift front bumper. Sides are a maybe, need to see how those mount up to the side skirts.
Generally, you should be able to swap out the module and sync/calibrate it using TechStream. Would work with AVS models: 2017+. Won't know for sure until someone tries it though. I know the ISF guys would swap out the updated steering controller from the later models, also the gauge cluster. Seems like a Lexus/Toyota thing to have that kind of stuff compatible.
Old Feb 3, 2022 | 08:16 AM
05RollaXRS's Avatar
05RollaXRS
Too bad, I really like the design of the front splitter especially the CF one for the 2020+ RCFs.
Old Feb 4, 2022 | 03:47 AM
lojackfty's Avatar
lojackfty
Default Good Alternatives
LEMS makes a nice dry carbon for 19 back and then Novel has some nice ones
Old Nov 13, 2023 | 09:57 AM
DiverseIS's Avatar
DiverseIS
$12k for the carbon wing. They are proud of that but it looks beautiful.
cvt
RC F (2015-present)
Dec 5, 2021 09:28 PM
05RollaXRS
RC F (2015-present)
May 19, 2021 09:43 PM
Boomin
RC F (2015-present)
Jun 18, 2020 07:32 AM
D2-AUTOSPORT
Wheels, Tires & Brakes Forum
15
Aug 19, 2007 05:48 PM
