Transmission Drain/Fill plug gasket
https://parts.belllexusnorthscottsda...6420-3503.html even if you don't buy from them, get used to looking things up here and search part numbers for best prices (generally Bell is the best though).
ATF Check Plug (5 mm Hex) Bolt:
Called Lexus Drain Plug #2...
Lexus 35106A...
Toyota 9034110021...
ATF Check Plug Washer:
Lexus 35106B...
Toyota 3517830010...
ATF Drain Plug (14 mm):
Called Lexus Drain Plug #1...
Lexus 35106A...
Toyota 9034110011...
ATF Drain Plug (14 mm) Washer:
Lexus 35106B...
ATF Fill Plug (24 mm):
Toyota 35015S...
Toyota 9034118059...
Toyota 9034118064...
Toyota 90341A0003...
ATF Fill Plug (24 mm) Washer:
Lexus 35015T...
Toyota 9030115004...
Lexus 35106A...
Lexus 35106B...
Lexus 35106A...
Lexus 35106B...
Toyota 35015S...
Lexus 35015T...
Indycar
Mar 28, 2021 06:03 PM
Hgspine
RX - 1st Gen (1999-2003)
May 14, 2018 05:36 PM
