04152-YZZA4 Oil Filter
Looks like it’s the same as the 51010 filter..
ok to use in my RCF?
Can anyone confirm?
Can anyone confirm?
They look similar or the same but don't cross over. Why not simply use 04152-51010?
I have a bunch of the YZZA4 in the garage and was hoping to save a trip to the store.
hahahah
hahahah
Tech Info Resource
I have run both. UOA shows no difference in results. I now buy the specified article in bulk so I don't have to run to the store for them.
BIG discussion on that here:
https://www.clublexus.com/forums/is-...il-filter.html
Folks had strong views
Back in '08 when I first got my "F" I used 51010, later I switched to the YZZA4 simply because it was cheaper. IMHO, both are the same - Dimensions are the same and filtering appeared to be the same. I have since switched to:
https://www.wixfilters.com/Lookup/Ex...PartNo=57041XP
Lou
Lou
Lou
Lou
cvt (09-04-20)
Lou,
I was hoping to buy a Wix and thought the number for a RCF was 57310...
I plan on using Pennzoil Ultra Platinum 5w-30 oil with wix filter.
^^^^It is, but as with Toyota, Wix has two PNs that have the same dimensions. 53710 is listed for passenger cars, 57041 for trucks and SUVs with V8 engines and for some reason the LC500h. 53710 doesn't have the premium XP version, 57041 does. I use 57041XP in my LC, previously I used it in my ISF.
I also use Ultra Platinum, but I use 10W/30 because I live in a hot summer climate with very mild winters.
Lou
Lou
rp2000r (09-05-20)
Got it done today. 9qts was perfect. I let the oil drain for a half hour then around the same on the oil filter. Used the Wix Xp filter and Pennzoil Ultra. Thanks for the info guys.
Received 1,059 Likes
Just the Facts..!!
Sure it works. But is it the same?? Nobody will ever know..
2 Facts I do know... They are NOT the same color.. If Lexus can supersede a part#, they will..
This part# has remained the same since 2008.. Same applies to the PCV Valve
Joe Z
rp2000r (09-05-20)
