New RCF owner...a few problems
buzzing / pulsing at idle is the low pressure fuel pumps, located under the driver seat. Does the buzzing come from that area? If so, it wasn't recalled as mentioned above, but there is a TSB on it to re flash the ECU with updated parameters which worked for me and many others.
I also get rattling from the sun roof area, i find it to be underneath the paneling surrounding the sunroof vs coming from the glass area itself. No fix found - annoying af
The moonroof is quite a mystery. I was touching every part to see if there is any wiggle that would make the rattling sound...but everything’s right as a drum. Very annoying...
The RSR springs are off!
Car handles much better. Not as jittery. Also notice it’s dumbed down some of the rattling on the moonroof. No more clunking noises too! Car feels right. I love it.
Now will just need to change to MPS 4S.
*Also good to know my shocks are still in good condition. No leaks.
Glad you got the RSR off. So I guess, I was right? LOL
It will get much better once PS4S tires replace the lion something tires.
Usually lowering springs are advertised to lower center of gravity, improve handling, etc. but going back to OEM really settled the car to the way I like it.
I have been burned by the Tein S-tech lowering springs I put on my Corolla XRS back in 2006. I blew all 4 shocks because they had a 2 inch lowered height, but handled like cr*p. I ended up going with Koni yellow adjustables (set to full stiff) and matched the Megan racing springs with 1 inch drop, which ended up being a good combination and still are working today.
The proper way is to go coil overs to improve over the OEM as it gives more adjust ability options
And there's even more to it when you consider roll center, instant center, roll couple and roll axis just to name a few things that all change (and often not for the better) with lowering. It's foolish to assume a fashionable lowering is actually going to improve performance, especially if you measure it with a timed course.
AZBlueDog
RX - 4th Gen (2016-2022)
Jan 26, 2018 07:45 AM
sugarlsu
Feb 21, 2008 05:53 PM
