RCF - Infotainment Media Start Up
Hi,
I have only owned my car for 1 month. One thing annoying me is each time I start up the car, the media is off and once I manually switch it on, it will be on default on DISC... This is the case no matter what, for example even if I shut the car off with music on and selected on USB. Is there anything in settings for me to resolve? Thanks, |
Do you have a phone mount using the CD slot? Mine would randomly push buttons until I spaced it away with rubber pads.
Another thing would be to make sure the buttons are clean, noting was spilled, etc. If that checks out, might be time for a trip to the dealership. |
Originally Posted by JayLexin
(Post 10708309)
Hi,
That is what I thought.
If shutting down the car and media source is left on, you would think it would turn on the previously selected source, but in my case its off and resets. I will hit up the dealer. |
There's a software update available that might fix it.
https://www.clublexus.com/forums/rc-...l#post10694354 |
Your software is probably corrupted somehow. Something weird happened to mine too recently. In the middle of my driving commute, the volume got really loud all of a sudden. On instinct I turned down the volume knob, that didn't work. I pressed all kind of buttons and nothing worked. I couldn't even shut it off, so I had to pull over and turned off the car. After the car restarted, everything went back to normal.
