The interior light in the door panel
the interior light that's inside the door panel is there any way to change that ?? maybe the color also , maybe a repeat question
i'm sure the door panel would have to come off,just not sure what else would have to be done ......so i would pay for the change also,was just hoping someone had made the change that could shed some light on how its done
If you are referring to the courtesy lights that come on when you open the doors, they are usually a simple 194 bulb replacement. Here's an examples from the ISF:
If you are referring to one inside the door handle, it's most likely a factory LED assembly, which cannot be replaced like a traditional incandescent bulb. You could swap it out, but it would be a specialist's job.
Nick C.
Nick C.
antlese
GX - 1st Gen (2003-2009)
12
May 30, 2015 12:39 PM
