Real or Synthetic Oil....
#61
Right, in every thing in our lives, the problem is lack of knowledge. In my working days I drove company car for almost 40 years. I got new car every 3 years. One guy never changed oil for that 3 year period, just kept topping up oil. When they did OFL on that car, you'd know what happened. It was a wreck....Well you are in the field then, an expert.
#62
^^^^WOW!!!! I have been driving for a bit over 60 years, thought I was the oldest guy here I probably change my oil too often and I use Pennzoil Platinum Ultra. I have been crawling under my cars and trucks and changing my own oil for more than 50 years now. I've never also never had an oil related problem
Lou
Lou
#63
^^^^WOW!!!! I have been driving for a bit over 60 years, thought I was the oldest guy here I probably change my oil too often and I use Pennzoil Platinum Plus. I have been crawling under my cars and trucks and changing my own oil for more than 50 years now. I've never also never had an oil related problem
Lou
Lou
tire/rim switch myself for all family vehicles, LOL!
#64
^^^^I'm South of Phoenix, North of Tucson. No need for seasonal tire changes here, though I do have a set of chains for my truck. Needed for high altitudes in winter. Didn't use 'em this year, but I used them once last year.
I spent 40 years of my working career at Raytheon. Started in Massachusetts and moved about the country, ending up in Tucson. Spent 23 years in Santa Barbara - Should NEVER have left
Lots of folks from Alberta spend their winters here - Snowbirds!
Lou
Lou
#66
I will change my oil in my RCF every 5 to 6 K miles with a new oil filter.
If you want to do at 10K miles, no one is stopping you.
Do it at your own risk.
The money so perceived as saved by doing 10K intervals will bite you in the end. The car just drives smoother with a fresh oil change.
Overdoing is wasting. Synthetic is superior to conventional oil. Unless one is racing , driving like maniac, driving under extreme conditions 10K change interval is good,
Also speaking of filter, have ever cut up the used filter? Most of them looks very clean. Now all cars are using unleaded fuels.
#67
Question: What if you just don't drive that much, say 5,000 mills per year? Is once a year on the oil change ok in this case? Even though it's only 5,000 miles, I certainly wouldn't want to wait any longer than this to change it.
#68
The additives in the oil break down over time. Which is why it is recommended to change it every 3-6 months regardless of mileage. Personally, I don't go more than 4 months with any type of oil. But I usually hit the mileage cap long before the time expires.
#70
Tech Info Resource
What evidence do you have to support this premise? I've never seen oil breaking down purely by time to be the case for a modern oil.
#71
Such low mileage driving increases moisture in the crankcase due to condensation. Water reacts with additives(chemical) causing acid. So that is why. That is why higher mileage vehicle always driven on highway has better engine condition than extremely low mileage cars(such as ol' lady only drove it to church on Sundays). Ever tasted with your tongue, fresh oil vs. used oil?
#72
I use Mobil 1 and one of my cars was use more or less as weekend fun car drove mostly highway and I wanted to try going the last interval based on miles and not based on time. I went 8120 miles in 4 years and 2 months and did a Blackstone LAB analysis.. This is what it says.. Read for yourself.. Anyone who believes oils go bad in a few months like marketing lies to sell oil or get you to service car more frequent.
#74
mobil 1 synthetic was invented in early 70's. it was shown to last forever and over 150k miles. engines have been run dry with mobil 1 synthetic and made it over 100k miles. oil is big business....change it every 3k miles
#75
