Cold-Blooded RC F
This morning, the rev limiter was at 7300 RPM as I accelerated in 2nd gear, manual mode, SPORT +. When I hit the upshift lever, the transmission would not shift into 3rd gear. About 5 miles later, I did a run on another on ramp and the transmission shifted fine. Tried it again on another on ramp and the shifting was normal. Hmmmm? The oil temperature was about 1/4 on the gauge during the first run and the outside temp was around 50 degrees, water temp was normal. I had started onto the freeway minutes earlier with a "cool" engine. Any thoughts?
IS25000
Apr 22, 2022 07:30 AM
sleepybobcat
RX - 1st Gen (1999-2003)
Feb 28, 2002 01:43 PM
