Does your RCF use oil?
I detailed my car yesterday and while I was under the hood, I thought I'd check the oil. I have 1300 miles on my car. I was surprised to see that the oil level was at the bottom mark on the dipstick. This was the first time I took a look at the oil. Perhaps the oil was never up to the top mark when I took delivery. Or is it normal for the V8 in the RCF to use a little oil? I came from ownership of a Honda Accord with a V6. I never had to look at the oil level in it. Whenever I did, it wasn't a drop down
My oil light came on at 4500miles and I had less than a quart in the car.
I travel with an extra quart in the trunk now.
I drive the aggressively in Sport plus ALL the time.
Wow, that seems a lil' excessive i would think for a Lexus but i know the old air-cooled Porsche's the Oil is their Lifeline & they Definitely go thru it (what kind are you using Db)! I'm sure one of the techs on here could answer this though! GL!
At 5000 I put in synthetic and then back to 10/30 at 10,000 miles because I want to change the oil every 5K based on the way I drive.
Guess i need to go ahead & put one in the Turtle Hull ( i know the young guys Won't know what that is)!
I had the oil light come on around 1500 so I added a quart of the whatever it said on the cap, I am going to run mineral oil and change it like the people who build the car say to do
3500 miles and it has not changed any, also I do hammer the car hitting redline daily.
I had the same issue at 2,500 miles-oil light came on and it was crazy low. Lexus took the car ran a bunch tests. Filled it and want me to come back in 1,100 miles. The sealed the film cap and dipstick with tape that says Lexus factory seal so I can't even check it. This really has me worried. They said it might not have been filled correctly at the factory, or it could be a real issue. BTW- no oil drips or residue anywhere, even tailpipes look clean.
I have over 7,500 miles since March. I use my car for business purposes so at least I am getting 57.5 Cents per mile for a lot of those miles . . .
There may be some oil consumption during break in. Should not be too alarming provided there are not other signs such as smoke, leaks and etc.
BTW, I have driven my car like I stole it since day one. My car actually had about 500 miles on it when I purchased it as it was used by Sports Illustrated for their hottie bikini model shoot.
Sponsor
Most of the oil consumption of this engine is due to the PCV system. That is why we designed the RR Racing Air/Oil Separator for the ISF. This model will also fit your RCF.
You are located about 1 hour from our shop... stop by and we will hook you up. Also, we have the Ultimate Steering Response System (USRS) for your car... you WILL NOT be disappointed.
-Rafi
ISF AOS Thread: https://www.clublexus.com/forums/is-...separator.html
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
-Rafi
-Rafi
