Thanks to Jason at Getyourwheels and Rafi/Sean at RR Racing.
Forgestar F14 Bronze Burst Deep Concave
20x9.5 +35 and 20x10.5 +45. 265/295/30/20 Michelin PS4
RR Racing Road and Track coilovers
Very nice setup! The offsets and sizes look spot on for the RCF. Jason and Josh at GYW are great to work with. How are the coilovers? Did you get camber arms or the USRS? Looks like you went pretty aggressive with the drop. Any issues?
I also have the USRS and SPC rear control arms on too. For the coilovers I left it at pre set from RR Racing and it's noticeably bouncier/stiff. But feels really good and solid. I only scrape when I hit small dips on freeway.
I’m running 255 up front and 285 in the rear. 20x9.5 front wheel and 20x11 rear with stock suspension
Originally Posted by Dbcooper13
I have ordered the White RCF with Carbon package and would like to change the wheels to a 5 spoke design.
I would like to use the tires that the vehicle comes with.
If you are like minded, please share your choice or options for the RCF.
Originally Posted by OURISF
Looks great...what size tires are you running...255/285? I am going to assume you are also on the stock suspension...correct?
^^^^Without offsets and tire aspect ratio, that information is not a lot of help
Also, assume your running a 285/30/20 in back tire manufacturer's wheel width recommendations for that size tire is 10" with a range of 9½" to 10 ½". So, your stretched.
Lou
Good call Lou...I was actually looking at these same wheels but with Matt Black centers and gloss black barrels...but I was going to go 265/295 for tires.
